Areber
Feb 02, 2021Aspirant
Used wifi dsl router/modem
Purchased a used netgear wireless router/modem. I am not able to connect to the internet. All other lights do come on. My computer recognizes it but can't connect. Contacted my internet provider an...
Areber
Feb 03, 2021Aspirant
Thanks, I didn't hold out much hope. Thought maybe someone would know something simple to try. Don't understand why isp would be necessary, and sorry pretty ignorant when it comes to most of how it all works. Don't even know what all the other letters mean. Again
thanks for responding.
pkgadd
Feb 03, 2021Luminary
The problem is that you do need to understand those "letters", if you want to configure your router, rather than letting an ISP provided modem-router to do magic autoconfiguration. Your ISP should provide you with the necessary information to configure your router, but this is often rather hidden or lacking - knowing the ISP might help others to either locate the necessary data or even provide it based on their personal experience.
While I'm not going through all of the mentioned acronyms, let's take a look at the primary question.
You only specify "dsl router/modem, but at no point do you actually provide the information what your ISP requires from your modem.
"dsl" is usually more correctly defined as "xDSL", the 'x' standing for two major (and several small) different technologies:
- ADSL (which consists of ADSL, ADSL2 and ADSL2+)
- VDSL (which consists of VDSL, VDSL2, VDSL2+vectoring, VDSL2+super-vectoring)
(and yes, this is a very rough simplification of the actual specification requirements, which also include the supported annex (A, B, J, M, ...) for ADSL or the necessary VDSL profiles (17b, 35b, ... and much more, once you look into the fine-print)
As mentioned before, the DGN2000 is a rather old device by now - a quick glance at its technical specifications only lists ADSL and ADSL2 as being supported (it's silent about ADSL2+, which leaves this open to speculation - given its release date I'd hope for it so be supported, but it's not explicitly listed; disclaimer: I have not dug into the detailed specs) - so if all you need is ADSL/ ADSL2 (at the correct annex!), you should be all set (and need to look further into the other afforementioned connenction details) - if your ISP expects you to talk VDSL (any flavour of it), this device wouldn't do (e.g. the DM200 could, up to VDSL2+vectoring/ profile 17b, but NOT VDSL2+super-vectoring/ profile 35b, for that you'd need an even more current device).
