BobRock
Mar 19, 2020Aspirant
Using 2nd AC1000 in AP Configuration
I just purchased a 2nd AC1000 router and will use it in AP mode. I have not received it yet. I think I want to make the first unit ethernet only. Is there a way to disable the wireless on the...
- Mar 19, 2020
> I just purchased a 2nd AC1000 router and will use it in AP mode. [...]
"AC1000" speed, not a model number. Look at the product label.
"R6080"?> I think I want to make the first unit ethernet only. Is there a way
> to disable the wireless on the first router so that it is just
> ethernet, [...]Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual. Read. Look for
"Enable or Disable the WiFi Radios". Further reading might be
helpful,too. For example, look for "Use the Router as a WiFi Access
Point Only".> [...] or is that a bad idea?
It's ok with me. I don't know why you're doing any of this.
> Once the AP is installed, how does my PC know which router it is
> talking to when I am setting up the security?If you give each radio its own unique SSID, then that name will make
it obvious. If you use the same SSID on different radios, then the
client device might need to make the choice.
antinode
Mar 19, 2020Guru
"R6080"?
> ethernet, [...]
Point Only".
