shrish
Nov 04, 2020Follower
Using as a repeater - JNR1010v2
I want to connect to a wifi network from my netgear router and use it as a repeater. How can I achieve it? Any pointers will be really appreciated. Shrish
Nov 04, 2020Guru - Experienced User
Page 44 of the manual walks you through it. Page 42-43 has requirements.
https://www.netgear.com/support/product/JNR1010v2
I probably wouldn't do it though. Reason why is the jnr1010 is a very base model device and to use as a repeater means using WEP security or no security. WEP isn't even slightly secure. Plus it limits you to 54mbps link speed (not throughput).
