JGL991
Aug 14, 2021Guide
USING GMAIL OUTGOING MAIL SERVER TO SEND ACCESS LOGS
I have tried to set up the access log to be mailed to me when i have wifi breaches by a mac address not on my access list but, It does not appear to work. Does anyone know exactly how to set this up...
DKN10
Nov 27, 2023Initiate
I was able to use gmail as my outgoing mail server:
Router:
Send to This E-mail Address: My Email Address
Your Outgoing Mail Server: smtp.gmail.com
Outgoing Mail Server Port Number: 465 using SSL, 587 using TLS
User Name: My Email Address
>>> Password:Generated Token from google if you use MFA, if not then your gmail login password will work as well.
After entering in your info on the router:
Google:
- login into google if you haven't already
- Go to SETTINGS (gear on the top right hand corner)
- Click on ACCOUNTS And IMPORT fourth tap over right next to inbox
- Click on Other Google Account Settings
- Type in the search box at the top: Enter App Passwords
- Click on App passwords: Enter your credentials at the login screen
- Name the password, Router, etc. Click CREATE
>>> Copy your token, Click DONE, and paste it in the password section of the router right below the User Name
- Save and wait a few seconds
- Click on logs right below administration and test the connection by sending a log and check your inbox.
>>> = PASSWORD INSTRUCTION
Website that provided instructions: https://www.123formbuilder.com/docs/setting-up-smtp-with-2-step-verification-on/
