JNBuckeye
Oct 18, 2020Initiate
Using NightHawk R8000 as a cascade router
Recently upgraded my primary router from NightHawk X6 R8000 to Orbi RBR750 (Mesh router with 2 satellites) in order to get better wireless coverage area through my home. Now, I'm finding that I want...
- Oct 18, 2020
> [...] I want to use my old NightHawk as a cascaded router to give me
> enough wired hookups for my various devices.You don't want another router; you want a network switch. It'd be
less trouble to invest the $20 or so for a cheap gigabit/s-capable
Ethernet switch. But...> o I have turned off DHCP on the NH, so that the Orbi can assign
> addresses to the devices.Reasonable, but insufficient.
> [...] Is there some other setting I need to tweak on the NH [...]
More than a tweak, I'd say.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Look for "Use the Router as a
Wireless Access Point". (That mode disables the DHCP server
implicitly.)
> o I turned off all the wireless radios on the NH, since I don't need
> that function. [...]Even so, "Wireless Access Point" mode is what you want, with or
without active radios.
antinode
Oct 18, 2020Guru
implicitly.)
JNBuckeye
BINGO! Set it up as an access point and it seems to do what I want now. If I were starting from scratch, the network switch would definitely be the easier and cheaper way to go, but I figured there must be a way to re-use the old router instead of throwing it on my ever-increasing pile of outdated tech. Many thanks!
