richscheer
Jul 23, 2021Aspirant
Using old router as wifi extender?
does anyone know if i can use my wndr3400v3 router as a wifi extender to extend the signal from my non-netgear router? if so, can you provide instructions on how to set up?
richscheer
Jul 26, 2021Aspirant
when hard wiring and setting up as an access point does that require new/different wifi name/password or can it use the same as my cable modem router already has? i have 15+ devices already set up to run off of the cable modem router and don't want to have to reprogram all of them manually.
Jul 26, 2021Guru - Experienced User
You can use the same ssid. but that isn't a mesh router/device. So devices will tend to be sticky and not roam like they would with a mesh setup that has the smart roaming specs built in.
You can try it and if you don't like it, simply log in and change the ssid to something seperate.
- richscheerJul 26, 2021Aspirant
thanks everyone. most devices are 'static' such lights or streaming devices in a tv so they shouldnt have an issue with "roaming" so i will give it a try
