Mindfac1
Aug 04, 2021Follower
Using power line adapter
Just needed to ask is it possible to use power line adapters In two separate buildings on same property?
antinode
Aug 04, 2021Guru
> [...] is it possible to use power line adapters In two separate
To communicate between the two buildings? Might depend on how power
is distributed to the two buildings. I'd need to run the experiment.
You might get/find better information sooner in a more appropriate
forum:
