Retired_Member
Sep 10, 2021Using wax610 access point with eax20 extender
TP-LINK wired router connected to Netgear wax610 access point via an Ethernet cable powered by an AC Adapter works flawlessly. When an Netgear eax20 Range Extender is added with same SSID as the Netge...
Retired_Member
Sep 11, 2021Ok, so since the Netgear EAX20 Range Extender is not compatible with Nighthawk AC1900 WiFi Access Point, what are the options to extend the WiFi network without having an Ethernet cable connected WiFi device? Will another Nighthawk AC1900 WiFi Access Point work like an extender without a Ethernet?
Any further assistance would be greatly appreciated.
michaelkenward
Sep 11, 2021Guru - Experienced User
Retired_Member wrote:
Ok, so since the Netgear EAX20 Range Extender is not compatible with Nighthawk AC1900 WiFi Access Point...
I did not say that. What I said was that you won't get a Mesh network. It may well be possible to set up separate wifi networks, or even networks with the same SSID. But they won't be Mesh.
Try your question in the right place and you might get better advice than you'll get from people who understand WiFi Routers.
