Tvestra
Dec 21, 2021Star
V1.0.4.122_10.0.95 Update on R6400v2 kills lon in page
I applied V1.0.4.122_10.0.95 to my Netgear R6400v2 router yesterday. Now I can’t access the router configuration GUI. Everything else works OK, but I can’t log into the router now. The update complet...
Brian_R
Jan 05, 2022Guide
Thank you Tvestra for discovering and posting that ports 80 and 443 are not open on the router after doing the firmware update to V1.0.4.122_10.0.95. It looks like the solution to this is to get the router to open ports 80 and 443 by doing a router reset and/or router reboots.
See thread linked below, message # 17:
This has been solved on my R6700v3 router with firmware V1.0.4.122_10.0.95 installed.
PhotonX30
Jan 06, 2022Aspirant
Reset & 1 hour router power off didn't help me. I then reset and installed 1.0.4.20. Now has GUI access. I don't know what "security vulnerabilities" this may have exposed, but at least I can access my router's settings while I explore other routers features and support reputation.
