Tvestra
Dec 22, 2021Star
V1.0.4.122_10.0.95 Update on R6400v2 kills lon in page
I applied V1.0.4.122_10.0.95 to my Netgear R6400v2 router yesterday. Now I can’t access the router configuration GUI. Everything else works OK, but I can’t log into the router now. The update complet...
Nivlac
Feb 10, 2022Aspirant
I just upgraded my R6400v2 router and now have the same problem The HTP/HTTPS ports are missing. NMAP shows only tcp port 5000 open. My other router which works fine shows tcp ports 8200, 443, and 80 open.
I can access the router with Nighthawk app and it show the firmware is up to date. There is no option to try reloading the firmware. I am on windows so I am limited on trying to reload the firmware.
Tarkus1
Mar 26, 2022Aspirant
#metoo Not that can’t do a factory reset. I need this pos to work.
No acknowledgment from netgear Buying a new non netgear. Then I’ll have this **bleep** as a backup and play the game. Then if I brick it I’ll go office space on it.
