Katanakahn
Dec 25, 2017Follower
Very slow downloads speeds reported
When I run a speedtest through my Router, I get reports of speeds around .12 Mbps. I am on MetroNet fiber and should get between 150-200 Mbps. This usually coincides with poor Streaming, which prom...
- Dec 27, 2017
Hi Katanakahn,
1. What is the exact firmware version of the router?
2. Have you tried resetting the router?
3. Does the issue persist on wires and wireless devices?
4. Does the issue persist on both bands (2.4GHz and 5GHz)?
Dexter
Community Team
DexterJB
Dec 27, 2017NETGEAR Moderator
Hi Katanakahn,
Dexter
Community Team
- DexterJBJan 02, 2018NETGEAR Moderator
Hi Katanakahn,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
