YVESDELAG
Jan 04, 2022Aspirant
voyant alim orange fixe sur access point WAX630
Bonjour, suite au branchement de mon point d'accès WAX630 le voyant alim/cloud reste continuellement orange fixe. Il est relié à une Freebox Delta par l'intermédiaire d'un switch Netgear GS305Pv...
schumaku
Jan 04, 2022Guru - Experienced User
Salut Yves,
The access point functions as a PoE PD and the Power/Cloud LED remains solid amber
When you connect the access point to a power source, the Power/Cloud LED lights
solid amber initially, then blinks amber slowly, and finally turns solid green or solid blue,
indicating that the startup procedure is complete and the access point is ready.
If the access point functions as a PoE PD and the Power/Cloud LED remains solid amber
after five minutes, the access point might not be receiving power at the required 802.3bt
(PoE++) level. For example, this situation might occur if the access point is connected
to a switch that provides only 802.3at (PoE+) rather than 802.3bt (PoE++).
Note: If the access point receives power at the 802.3at (PoE+) level, the access point
limits its operation to 2x2 streams for 2.4 GHz radio and 5 GHz low band radio, which
results in half the peak throughput for these two radios. If the access point receives
power at the 802.3af (PoE) level, the 2.4 GHz radio and 5 GHz low band radios remain
off. In either case, the 5 GHz high band radio functions normally.
Do the following:
1. Disconnect and reconnect the Ethernet cable at the LAN 1/PoE++ port on the access
point and at the 802.3bt (PoE++) port on the PoE++ switch.
The access point restarts.
2. If the Power/Cloud LED remains solid amber after five minutes, check to see why
the PoE++ switch cannot provide sufficient PoE power to the access point.
Most likely, the PoE power budget of the PoE++ switch is oversubscribed and you
might need to disconnect another PoE device from the PoE++ switch to make
sufficient PoE power available for the access point.
If the error persists, see Power/Cloud LED remains solid amber on page 227
FMI: -> Insight Managed WiFi 6 AX6000 Tri-band Multi-Gig Access Point Model WAX630 User Manual p.227/228 ff.
YVESDELAG wrote:
Il est relié à une Freebox Delta par l'intermédiaire d'un switch Netgear GS305Pv2 avec un cable neuf CAT7 d'une quinzaine de mètres.
Voila, cette switch est sulement 802.3af (PoE) et 802.3at (PoE+) - ces 30 W suffit pas pour cette WAX630, pourtant la signalisation est 802.3at (25.5W max).
FMI: -> Data Sheed 300 Series - SOHO Gigabit Ethernet Unmanaged Switches with PoE
YVESDELAG
Thanks a lot for your precise and precious answer... I am going to get a new switch.
Yves
