Shyam6784's avatar
Shyam6784
VPN doesn't establish client-to-gateway tunnel | no VPN for Internet browsing
I bought Netgear WNR614 WiFi router 6 months back. I'm facing a strange issue with this router.
Router doesn't allow to establish VPN tunnel through it (from my home to company's VPN gateway).
I get IPv4 Public IP from ISP. If I connect the uplink to my laptop directly, I'm able to establish VPN session.
I don't have provision to disable Firewall in the router webpage.
Router Firmware Version: V1.1.0.32_1.0.1
I'm using Windows7 os in my laptop.
Any help to resolve this issue would be appreciated.
Thanks,
Shyam.
    • Shyam6784's avatar
      Shyam6784
      Thanks ElaineM,
      After adding Port Forwarding records for ports 500 and 1701-1723, I'm able to establish VPN tunnel through the router.
      Shyam
      • ElaineM's avatar
        ElaineM
        NETGEAR Employee Retired
        That's good news! Thank you for the update.
