DevtaSingh
Jun 10, 2022Follower
Vpn not working in r6220
I have an isp provided main router. I am using netgear r6220 as an access point. Cant use port forwarding on main router (limitation from isp). I want to access usb attached to r6220 so i have setup vpn service on it and trying to connect to it using openVpn from device on another network. But openVpn client gets stuck in connecting status.
1 Reply
DevtaSingh wrote:
I have an isp provided main router. I am using netgear r6220 as an access point.In AP mode, your R6220 does not support most of the features you want to use.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
You might want to see if the unnamed "main router" has a modem only (bridge) mode option.
Then again the R6220 is a pretty basic router,
