Merijn
Oct 27, 2016Tutor
VPN passthrough on Netgear R6400 (AC1750)
Hi all, At the moment I'm having trouble setting up vpn passthrough on my new Netgear R6400 with the latest firmware. When setting up the port forwarding for the L2TP vpn solution (udp ports 17...
- Oct 27, 2016
Hi Merijn,
1. Have you tried forwarding port 1701? You can check the link below.
http://kb.netgear.com/app/answers/detail/a_id/966
2. Have you tried setting DMZ for the NAS for isolation purposes? We also recommend doing address reservation for the NAS to have its IP consistent.
3. Have you tried other firmware versions?
Dexter
Community Team
DexterJB
Oct 27, 2016NETGEAR Moderator
Hi Merijn,
Dexter
Community Team
Merijn
Oct 27, 2016Tutor
Hi Dexter,
I added port 1701, but without any luck. I also found the manual for troubleshooting vpn passthrough, but unfortunately after following all tips on this page, the problem still exists.
I will try to setup vps passthrough with the older firmware, hopefully this will fix my issue. I'll let you know...
- DexterJBOct 30, 2016NETGEAR Moderator
Hi Merijn,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- MerijnOct 31, 2016Tutor
Hi Dexter,
I just tested with an old firmware version, after which I had to forward the specific ports for vpn again and finally it worked! Probably there is some issue with port forwarding in the latest firmware version, but the firmware version with which vpn forwarding is working fine right now is version V1.0.1.6_1.0.4!
Many thanks for your help!Merijn
