jalford
Feb 03, 2022Tutor
WAC104 5 GHZ Signal slows down to less than 1 MHz download speed.
I have a Netgear R6400v2 Wireless Dual Band Rounter connected to the internet modem (Charter). I have a Tri-level house and this item is installed upstairs in a middle bedroom. I also have two WAC10...
Feb 03, 2022Guru - Experienced User
The R6400 is a pretty base model device.
What firmware is on it?
Any chance you have a different router you could test it on? The R6400 is a pretty base model device.
jalford
Feb 04, 2022Tutor
Current Firmware versiion is V1.0.4.106_10.0.80. Noticed there was anew firmware update this morning.
Performed a speed test using my cell phone connected to the WAC104 AP 5GHz channel at 6 am. Results were 60.2 MB download and 11.4 upload, which is good for my system. Just did another check using the same cell phone and download was .88 MB. Upload 4.43 MB. I plugged in a laptop to the WAC 104 and perfromed a speed test. Download 116 - Upload 12.
So, for some reason the 5 Gig almost dissapears. The 2.4 hasn't changed from this morning. Is there some settings in the Access Point that would make this difference. Or how i have my system set up? The 5 Gig on the second WAC slows down some if you turn on the Roku, but still operates.
I do not have another router.
- plemansFeb 04, 2022Guru - Experienced User
After you changed firmwares, did you try a factory reset?
- jalfordFeb 05, 2022Tutor
As to the Router, I don't remember and that is the one that has another update. The symptom has been happening for quite a while and assumed the problem is with the Access Point since the other one operates correctly. I haven't checked the Access Point (WAC104) to see if it has an update.
- plemansFeb 06, 2022Guru - Experienced User
I'd check a couple things.
1. try moving the access point next to the router (for testing) and hardwire it in with a known good 6ft cable.
2. Check the router an ensure qos is disabled
3. try swapping positions on the access points to see if its a location issue or a access point issue.
