jalford
Feb 03, 2022Tutor
WAC104 5 GHZ Signal slows down to less than 1 MHz download speed.
I have a Netgear R6400v2 Wireless Dual Band Rounter connected to the internet modem (Charter). I have a Tri-level house and this item is installed upstairs in a middle bedroom. I also have two WAC10...
jalford
Feb 05, 2022Tutor
As to the Router, I don't remember and that is the one that has another update. The symptom has been happening for quite a while and assumed the problem is with the Access Point since the other one operates correctly. I haven't checked the Access Point (WAC104) to see if it has an update.
Feb 06, 2022Guru - Experienced User
I'd check a couple things.
1. try moving the access point next to the router (for testing) and hardwire it in with a known good 6ft cable.
2. Check the router an ensure qos is disabled
3. try swapping positions on the access points to see if its a location issue or a access point issue.
