Foresthill
Jan 02, 2021Tutor
WAC104 and WN2500RP strangeness
I was not sure where to post this as I can't tell for sure what is causing the problem. About 2 years ago I had solar installed and the inverters are in my garage. They communicate via the Inter...
- Jan 10, 2021
The 3700 arrived, was configured and installed and that whole part of the network is performing perfectly. The 104 is headed for the recycling bin.
Foresthill
Jan 03, 2021Tutor
Last night I was able to connect my Windows 10 laptop to the 2.4G network on the WAC104 and it ran normally. It was still working fine this morning. I used my Samsung Galaxy S10+ to successfully connect to the 2.4G SSID on the 104 but it would not connect to the 5G SSID. The 2500 connect to the 3000 uses the 2.4G band as that is all that is offered. I have a spare 2500 which I will configure to use only the 2.4G on the 104 and see if that will run.
Foresthill
Jan 03, 2021Tutor
I have verified proper operation between the 2500 and the 104 as long as I avoid the 5G SSID. I am going to order a 3700 to replace the 104, set it up as an access point in the garage and hopefully be done with this mess.
- ForesthillJan 10, 2021Tutor
