Foresthill's avatar
Jan 02, 2021
WAC104 and WN2500RP strangeness
I was not sure where to post this as I can't tell for sure what is causing the problem.   About 2 years ago I had solar installed and the inverters are in my garage.  They communicate via the Inter...
  • Foresthill's avatar
    Foresthill
    Jan 10, 2021
    The 3700 arrived, was configured and installed and that whole part of the network is performing perfectly.  The 104 is headed for the recycling bin.
