banderson01
Sep 09, 2021Tutor
WAC104 Bricked
I was performing a firmware update on my WAC104 access point and it apparently failed. Now when I turn on the AP, the power light comes on and is steady. As soon as I plug an ethernet cable into any ...
- Sep 11, 2021
I had already tried nmrpflash and failed but I failed to notice that a switch between the PC and AP was needed. After I added a switch it worked fine. Thanks for your help.
banderson01
Sep 11, 2021Tutor
Sep 11, 2021Guru - Experienced User
glad it worked for you.
