StVeronus
Feb 13, 2022Aspirant
WAC104 Can't reset after bridge mode
I have a WAC104 that was in Bridge Mode. I reset the primary router already (R6220). This AP doesn't want to reset. Every time I try, it goes back to broadcasting the bridged SSIDs. So I can't ge...
StVeronus
Feb 16, 2022Aspirant
Thanks Plemans. I put the repeater's MAC into the router and saved it. I'm able to connect to the network on the old SSID and password, but it is different than what is configured for the router now. I can't seem to find the web interface for the repeater to connect and configure it. It isn't responding on 192.168.0.100. I tried to scan the network/dhcp logs for the MAC, but didn't see it.
Feb 16, 2022Guru - Experienced User
did you change the router's ip address?
Check what the R6220's current ip address is. Your r6220 and the wac need to be in the same subnet
- StVeronusFeb 16, 2022Aspirant
I did change the IP from when I had the repeater on the network originally. Should I change the router's IP back to the old address?
- plemansFeb 16, 2022Guru - Experienced User
Yes, change it back to the one you had it one. the wac has to be in the same subnet as the router to access it
I set the routers IP back to what it was. How do I find the repeater's IP? It still isn't showing in logs, arp table or IP Scan.
