Zaluker
Feb 13, 2020Aspirant
WAC124 AC2000 can't reset, LEDs blinking
When I power-on the WAC124, after initial boot the power and USB LEDs blink alternately. You can't log in to the device or use it. I've tried holding down the reset button for ages, and also powering...
- Feb 21, 2020
I think the WAC124 has a 3 year warranty from data of purchase. have you tried going to
mynetgear at the top, registering an account and then device? it should tell you if you've still got the warranty on it (provided you bought it from an authorized seller and/or new)
Feb 13, 2020Guru - Experienced User
Not sure on the business class stuff but have you tried recoving it via tftp?
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Zaluker
Feb 21, 2020Aspirant
Thanks.
Sadly, I can't even get an IP connection to the device, so I think it's a goner.
