JLD95
Jan 09, 2022Aspirant
WAC124 on port 2.5G runs in 100M speed
Hi, When I connect Wac124 on 1G RJ45 port, all works with 1G speed but when I connect Wac124 on 2.5G port, WAC is detected with 100M speed. Any setting in order to works on 2.5G port : it should work...
JLD95
Jan 11, 2022Aspirant
Yes I have WAC124.
2.5 source is Freebox Pop, see for example. https://www.inpact-hardware.com/article/1944/la-freebox-pop-v8-cote-technique
The cable to connect on 1G port or 2.5G: it's Cat7 cable approx. 7m length with a 30cm standard cable. Exact cable is LW Electronic Câble réseau Gigabit Haute qualité S/FTP PIMF 1000MHz Cat7 4x2xAWG23 LSZH Câble d'installation blindé 50m Orange https://www.amazon.fr/dp/B077XMQMPC/ref=cm_sw_r_apan_glt_i_B49FWZSX57N29Q81P9FX?_encoding=UTF8&psc=1
schumaku
Jan 11, 2022Guru - Experienced User
Because of Gigabit works, the cable is almost certainly OK (and ways over the required specs for MultiGig btw.).
YeZ unclear where we should start here - could well be a problem with the named box, too.
- RaghuHRJan 12, 2022NETGEAR Expert
JLD95 We checked your feedback but we are able to see 1G speed. See the attached screen shot. Please check the configuration on Freebox Pop. Please attach the screen shot where it is showing 100M
- JLD95Jan 13, 2022Aspirant
Hi,
Screenshot to see WAC124 works in 1G speed when it's connected to Freebox 1G port:.- JLD95Jan 13, 2022Aspirant
At now, I can't login to WAC124, I have error message "resource validation error" . I tried new password but same error.
So no screenshot in 100M mode for the moment
