JLD95
Jan 09, 2022Aspirant
WAC124 on port 2.5G runs in 100M speed
Hi, When I connect Wac124 on 1G RJ45 port, all works with 1G speed but when I connect Wac124 on 2.5G port, WAC is detected with 100M speed. Any setting in order to works on 2.5G port : it should work...
schumaku
Jan 11, 2022Guru - Experienced User
Because of Gigabit works, the cable is almost certainly OK (and ways over the required specs for MultiGig btw.).
YeZ unclear where we should start here - could well be a problem with the named box, too.
RaghuHR
Jan 12, 2022NETGEAR Expert
JLD95 We checked your feedback but we are able to see 1G speed. See the attached screen shot. Please check the configuration on Freebox Pop. Please attach the screen shot where it is showing 100M
- JLD95Jan 13, 2022Aspirant
Hi,
Screenshot to see WAC124 works in 1G speed when it's connected to Freebox 1G port:.- JLD95Jan 13, 2022Aspirant
At now, I can't login to WAC124, I have error message "resource validation error" . I tried new password but same error.
So no screenshot in 100M mode for the moment
- JLD95Jan 13, 2022AspirantWorks again but I can't see Wan status, only the 4 ports: a setting to display WAN on console? Can you describe how to access in order to have the right screen. I think is Advanced/WPS wizard/LAN port/Show Statistics ?
