kscrib's avatar
kscrib
Tutor
Mar 06, 2020
WAC740 AF Power (Radio Off) error on WC7500
I have a WAC740 connected to a Cisco 2960S (POE+ / 803.2at) switch with 740w of POE+ power.  I have tried this with the WAC740 being the ONLY device connected to the 2960S switch and had the same pro...
  • kscrib's avatar
    kscrib
    Mar 11, 2020
    OK - disregard all the commands in the 2nd post.
    The problem is that by default the Cisco 2960s switch had LLDP disabled and was running the Cisco proprietary CDP. CDP does not properly communicate with non-Cisco devices.  LLDP is used to communicate things like power negotiation between the PSE (Power Source - aka switch) and PD (Power Device - aka WAC740 AP).  The fix was a couple of simple commands:
    Cisco2960s# configure terminal
    Configuring from terminal, memory, or network [terminal]? Enter configuration commands, one per line. End with CNTL/Z.
    Cisco2960s(config)# no run cdp
    Cisco2960s(config)# lldp run
    Cisco2960s(config)# end
    Cisco2960s# copy running-config startup-config
    That is all it takes to solve it!
    You can see below where LLPD does the power negotiation:
    Cisco2960s# show power inline gi1/0/41 detail
    Interface: Gi1/0/41
    Inline Power Mode: auto
    Operational status: on
    Device Detected: no
    Device Type: Ieee PD
    IEEE Class: 4
    Discovery mechanism used/configured: Unknown
    Police: off
    Power Allocated
    Admin Value: 30.0
    Power drawn from the source: 30.0
    Power available to the device: 30.0
    Actual consumption
    Measured at the port: 11.4
    Maximum Power drawn by the device since powered on: 13.7
    Absent Counter: 0
    Over Current Counter: 0
    Short Current Counter: 0
    Mosfet Counter: 0
    Invalid Signature Counter: 0
    Power Denied Counter: 0
    Power Negotiation Used: IEEE 802.3at LLDP
    LLDP Power Negotiation --Sent to PD--         --Rcvd from PD--
    Power Type:                      Type 2 PSE             Type 2 PD
    Power Source:                   Primary                   PSE
    Power Priority:                   low                          critical
    Requested Power(W):       25.5                         25.5
    Allocated Power(W):         25.5                         25.5
    Four-Pair PoE Supported: No
    Spare Pair Power Enabled: No
    Four-Pair PD Architecture: N/A
