HJTeix's avatar
HJTeix
Guide
Aug 20, 2019
Wan light is red.
I bridged Zoom 5350 and plugged in Netgear already programmed and with the right mac. connected, but the wan light on the router has turned red and does not change to any green!
What to do ?
Thank you.
    First try starting things in the right order.
    • Turn off and unplug modem.
    • Turn off router and computers.
    • Plug in and turn on modem. Wait 2 minutes for it to connect.
    • Turn on the router and wait 2 minutes for it connect.
    • Turn on computers and rest of network.
    I assume that you confirmed that the modem can connect to the Internet before you brought the router into the picture.
    Routers cannot do magic. They can't mend a broken Internet connection.
    • HJTeix's avatar
      HJTeix
      Guide
      Clarifying, if I turn the zoom on the pc has no internet connection and through the router yes, but the wan light remained red.
      • Sadly, that does not clarify much for me.
        Can you connect the PC to the Internet without using the router?
        If I interpret this bit correctly, the answer is no:
        HJTeix wrote:
        Clarifying, if I turn the zoom on the pc has no internet connection ...
        No amount of messing around with the R6080 will get you anywhere without that basic first step.
