jrab
Jun 27, 2016Aspirant
Want to access LAN resources over Wifi WNDR4500v3
Hello I have a WNDR4500v3 – N900 WiFi Dual Band Gigabit Router that I have set up for my small business. We would like to be able to access the same network folders that we can access over LAN, over ...
- Jun 29, 2016
Thanks for responding and welcoming me to the community.
I meant that I had folders on a computer on the network that I could share with devices on the LAN, but could not see those same folders/devices when accessing the network via WiFi.
I resolved the issue by selecting to use AP Mode for the device.
ElaineM
Jun 28, 2016NETGEAR Employee Retired
Hello jrab
Welcome to the community!
What do you mean by accessing the same network folders?
Are the network folders from a computer? From a NAS? From a USB HD attached to the router?
Can you kindly elaborate more on what you're trying to achieve?
jrab
Jun 29, 2016Aspirant
- ElaineMJun 29, 2016NETGEAR Employee Retired
Sounds like wireless isolation is enabled.
Thank you for the update!
