JRRouter
Nov 14, 2022Aspirant
Was my router hacked
The weirdest thing happened to me this morning, when I was on a Zoom meeting for the first day on the job. Suddenly the router was disconnected from internet. I have to call the ISP to figure out ...
Nov 14, 2022Guru - Experienced User
What router model do you have?
Is the Guest Network enabled by chance? 192.168.2.x is usually a device that's connected to the Guest Network.
Do you have the time set up right on the router?
- JRRouterNov 14, 2022Aspirant
There's no modem it's using PPPoE through the building I live at, and the 192.168.2.0/24 subnet is my primary network. I just set it up that way.
Hardware Version
R6250
Firmware Version
V1.0.4.38_10.1.30- FURRYe38Nov 14, 2022Guru - Experienced User
Check your devices for MAC addresses against what you see in the logs.
Those are all good. Matching for just the 4 or 5 devices I have connected to the two interfaces on Netgear. No more no less.
Do you any idea why the 2024 date would have appeared in my logs?
