JRRouter
Nov 14, 2022Aspirant
Was my router hacked
The weirdest thing happened to me this morning, when I was on a Zoom meeting for the first day on the job. Suddenly the router was disconnected from internet. I have to call the ISP to figure out ...
Nov 14, 2022Guru - Experienced User
What router model do you have?
Is the Guest Network enabled by chance? 192.168.2.x is usually a device that's connected to the Guest Network.
Do you have the time set up right on the router?
JRRouter
Hardware Version
R6250
Firmware Version
V1.0.4.38_10.1.30
- FURRYe38Nov 14, 2022Guru - Experienced User
Check your devices for MAC addresses against what you see in the logs.
- JRRouterNov 14, 2022Aspirant
Those are all good. Matching for just the 4 or 5 devices I have connected to the two interfaces on Netgear. No more no less.
Do you any idea why the 2024 date would have appeared in my logs?
Possible some glitch in the router logging system. Anything is possible sometimes.
I presume you have the NTP feature enabled and set correctly?
