JRRouter
Nov 14, 2022Aspirant
Was my router hacked
The weirdest thing happened to me this morning, when I was on a Zoom meeting for the first day on the job. Suddenly the router was disconnected from internet. I have to call the ISP to figure out ...
Nov 14, 2022Guru - Experienced User
Check your devices for MAC addresses against what you see in the logs.
JRRouter
Those are all good. Matching for just the 4 or 5 devices I have connected to the two interfaces on Netgear. No more no less.
Do you any idea why the 2024 date would have appeared in my logs?
- FURRYe38Nov 14, 2022Guru - Experienced User
Possible some glitch in the router logging system. Anything is possible sometimes.
I presume you have the NTP feature enabled and set correctly?
- JRRouterNov 15, 2022Aspirant
This doesn't really add to my understanding of what happened. If the log glitch happened during a system crash, are you saying that both the router would go OFFLINE and I would lose connection with all devices, but then somehow the log glitch doesn't show any record of anything before? That is what I am so suspicious about. Can you please comment on the small chance that the device could have been breached and whether there's any real evidence for me to consider a factory reset on my router device?
