Swiftfox99
May 16, 2017Aspirant
WD My Book HDD not being detected in ReadyShare Vault for R6400
Hello, I have attached a WD 1TB My Book to my R6400 but the ReadyShare Vault is not detecting the drive. I have verified that it is detected through the Router Admin page and double checked that ...
- May 24, 2017
Hi Swiftfox99,
1. Please try using another storage device for isolation.
2. If it is an option, please try resetting the router.
3. If the issue persists, you can try re-flashing the firmware then do a factory reset.
Dexter
Community Team
DexterJB
May 17, 2017NETGEAR Moderator
Hi Swiftfox99,
1. What is the firmware version of the router?
2. Please try disabling or adding the ReadySHARE Vault as an exception to your security/anti-virus software.
3. Please try uninstalling and re-installing the program.
Dexter
Community Team
Swiftfox99
May 18, 2017Aspirant
Hello DexterJB,
1) Firmware Version
V1.0.1.22_1.0.17
2) Double Checked the firewall/security softward, nothing is blocking ReadyShare as far as I can tell.
3) I did the uninstall/reinstall still no luck on the detecting the harddrive through Readyshare Vault.
I am still able to see it by going to \\readyshare through Windows Explorer and it shows up in the Router Admin page still.
Thanks
- Swiftfox99May 21, 2017Aspirant
