Swiftfox99
May 16, 2017Aspirant
WD My Book HDD not being detected in ReadyShare Vault for R6400
Hello, I have attached a WD 1TB My Book to my R6400 but the ReadyShare Vault is not detecting the drive. I have verified that it is detected through the Router Admin page and double checked that ...
- May 24, 2017
Hi Swiftfox99,
1. Please try using another storage device for isolation.
2. If it is an option, please try resetting the router.
3. If the issue persists, you can try re-flashing the firmware then do a factory reset.
Dexter
Community Team
DexterJB
May 22, 2017NETGEAR Moderator
Hi Swiftfox99,
1. Please try using another PC.
2. Did you try temporarily disabling your security software or adding the program to a whitelist?
Dexter
Community Team
Swiftfox99
May 24, 2017Aspirant
Hi DexterJB,
I verified from another PC that the drive is still not being detected in ReadyShare.
I also disabled the security and firewall temporarily and it is still not detecting the harddrive attached to the router.
Here are my usb settings in the admin page:
Verified that I can still get to it through Explorer.
Thanks,
James
- DexterJBMay 24, 2017NETGEAR Moderator
Hi Swiftfox99,
Dexter
Community Team
- DexterJBMay 30, 2017NETGEAR Moderator
Hi Swiftfox99,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
