jrmm
Apr 02, 2023Aspirant
Weak Network Security warning on iPhone
I have an R7850 Netgear router and use Nighthawk to monitor my network. I recently activated an iPhone SE. Ever since, I’ve had problems with weak protection showing up on the iPhone and it won’t con...
Apr 03, 2023Guru - Experienced User
Apple is great at trying to push people to use the latest security standards. the newest is wpa3 but most older routers don't support wpa3 and only use wpa2. I wouldn't worry about it to much. You should be able to go in on the apple and disable the warnings
