mpp6607
Dec 19, 2020Follower
Weak Signal
I have Powerline 1000 set up but the Pick a Plu LED is Red in the room I need it in. I cannot move the router any closer is there anyway to boost the signal? I look forward to hearing from you.
You can't "boost the signal" but you can troubleshoot it and the home to help with signal.
here's one article on it.
- MP66Aspirant
Thanks for the link, what happens if I add another powerline between the router and the room with a weak signal?
It connects to the powerline?
It doesn't boost/repeat the signal.
- MP66Aspirant
Ok so othing really I can do
