thewisegrow
Feb 08, 2021Aspirant
Weak Wireless Connection Crashes Entire Network
My R6100 wireless router works well so long as connected devices recieve a strong signal. If a device's wireless connection receives a weak signal by moving too far away from the router for a few sec...
- Feb 11, 2021
> [...] It still kept the newest firmware version after resetting
> though. [...]To be expected. "factory reset" is a misnomer. It's a _settings_
reset, and has no effect on the firmware.> [...] potentially resetting to the original firmware. [...]
Visit http://netgear.com/support , put in your model number, and look
for Downloads. (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".) Find the kit(s).
Download the kit(s) you want. Read the "Release Notes" file for
instructions. (In the User Manual, look for "firmware", and,
especially, for a topic like "Manually Upload Firmware to the Router".)
When that fails because of a deficient User Manual, try:
thewisegrow
Feb 11, 2021Aspirant
I held down the reset button for longer this time and I noticed the router was successfully reset to factory settings. It still kept the newest firmware version after resetting though. If my issue persists I will explore my options in terms of potentially resetting to the original firmware. Maybe everything is fixed now. Thank you very much for your help.
antinode
Feb 11, 2021Guru
> though. [...]
