ddeeds33's avatar
ddeeds33
Website blocking no longer working
I just update to the latest firmware, 1.0.0.22, and website blocking no longer works.  Can anyone else confirm that?
  • Hi ddeeds33,
    Please make sure that a factory reset has been done after updating the router's firmware.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi ddeeds33,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi ddeeds33,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
      • ddeeds33's avatar
        ddeeds33
        Hi - I was traveling and didn't have a chance to reply sooner.
        I did the factory reset and there was no change.
        However, a couple days later the web sites started being blocked again.
