emacpa9
Apr 30, 2017Aspirant
Website for logging in to my netgear router
I have a netgear wireless router. I would like to login to my router but do not know the website to use. Thanks for any help you can provide.
- Apr 30, 2017
routerlogin.com or routerlogin.net. Either should work. You can also use the router's LAN IP address. It will be the same IP address as the default gateway on any device connected to the router.
