dvos11's avatar
dvos11
WGR614v10 router stopped allowing connections
Our Netgear router stopped allowing us to connect yesterday.  We've tried using our laptop (Surface Pro), Iphones, and Ipad, and all get same response: Unable to connect to Network "Netgear". As yo...
  • wcalifas831's avatar
    Apr 21, 2018
    Several things you can try. Now that you've reset it to defaults you'll have to try and log into your router with an ethernet cord from your laptop into one of the four ports on the back. Try logging into it, if that does not work go to the command prompt on your computer and see if you can ping it by typing ipconfig and see if you get a response back. To download the firmware you'll have to go to netgear's support site and download the firmware for your specific model. By any chance did you see if it might be the power adapter to the router that has gone bad?
