Allied605
Apr 25, 2024Aspirant
WGR614v7. Changing encryption type from WEP to WPA2.
Can I change the encryption type from WEP to WPA2 without changing any other settings (such as username or password)? My new security cameras require WPA2 level encryption on my router. Thanks
- May 03, 2024In short, yes on many. But some explicitly require you need to tell them what encryption you use by selecting the right option they provide
Apr 26, 2024Guru - Experienced User
Instead of changing security protocols, change the router.
that is an old wireless g router that is single band from 2003. (just think, in a year, it can drink!)
Before wireless security camera's were a thing.
Not that you couldn't get it to work but its so old/slow that it'll bottleneck your network and proably make the camera's seem pretty crappy.
Time to upgrade to something from this decade.
michaelkenward
Make that this century. I'd lay money on it having its origins back in the 20th century.
- Allied605May 03, 2024AspirantThanks for the advice. I probably will.
