Allied605
Apr 25, 2024Aspirant
WGR614v7. Changing encryption type from WEP to WPA2.
Can I change the encryption type from WEP to WPA2 without changing any other settings (such as username or password)? My new security cameras require WPA2 level encryption on my router. Thanks
- May 03, 2024In short, yes on many. But some explicitly require you need to tell them what encryption you use by selecting the right option they provide
Apr 26, 2024Guru - Experienced User
Instead of changing security protocols, change the router.
that is an old wireless g router that is single band from 2003. (just think, in a year, it can drink!)
Before wireless security camera's were a thing.
Not that you couldn't get it to work but its so old/slow that it'll bottleneck your network and proably make the camera's seem pretty crappy.
Time to upgrade to something from this decade.
Allied605
May 03, 2024Aspirant
Thanks for your reply. I will probably change routers. Still, can I change encryption levels without disrupting my network devices?
- microchip8May 03, 2024MasterIn short, yes on many. But some explicitly require you need to tell them what encryption you use by selecting the right option they provide
- Allied605May 03, 2024AspirantThank you for the advice. I will change the encryption level on this router until I get a new one, and hope everything stays online.
- microchip8May 03, 2024MasterIf not, usually only thing you need to change is the level on the device. No need to re-enter passwords or so
