DavidMW45
Jul 10, 2021Tutor
WGR614v7 for use as wireless access point
I want to configure a WGR614v7 for use as a wireless access point in my garden studio. There is an ethernet cable from the main router in the house. I need to have ethernet ports as well as wi-fi and...
- Jul 18, 2021
Just as a follow up, the new WAC104 works fine, but as with the WGR614 I had great difficulty accessing the setup page. This eventually turned out to be down to the antivirus software blocking access. Once I'd disabled this, I was able to get in and set a decent password for the wi-fi.
Quite possibly I'd have been able to re-configure the WGR614 as an access point if I'd realised this sooner! If I've nothing better to do I'll give it a go!
Thanks for the help.
antinode
Jul 10, 2021Guru
> I'm not able to access the configuration page. [...]
When you connect what, exactly, to what, exactly, how, exactly?
If you connect nothing to the WGR614v7 except (its power adapter and)
a computer to one of its LAN Ethernet ports, then it should work as
described in its documentation.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get some. Read.
As I read its documentation, your antique doesn't have a WAP mode
option, so you'll need to use a procedure like the one at:
https://community.netgear.com/t5/x/x/m-p/1463500
That's written for a Netgear C6300-as-WAP, but the steps are about the
same for any other router (any make/model) which lacks a one-step WAP
option. If the router which you're reconfiguring has a WAN/Internet
Ethernet port (unlike a Cxxxx), then leave it unconnected.
- DavidMW45Jul 12, 2021Tutor
Thanks for the advice. I found the process of accessing the configuration page and making the necessary changes altogether too challenging, and wasn't confident of achieving the results I need. I've ordered a dedicated Wi-Fi access point from Netgear.
Thanks again.
- DavidMW45Jul 18, 2021Tutor
- michaelkenwardJul 19, 2021Guru - Experienced User
Good feedback.
Which software? Have you alerted them to the grief they caused you?
- DavidMW45Jul 19, 2021Tutor
It's ESET Cyber Security for Mac. Yes, I've alerted them to the issue and they don't seem to have a solution. Once you know the cause it's easy to work round it by disabling the anti-virus, or creating an exception.
It's a pity it took me more than a week and the price of a new WAP to work it out!
