Ron38's avatar
Ron38
WGT624NA Reset network security code?
My friend had this router put away and wants to use it again, but has lost the security code.
Is there any way to reset it so I could enter a new one?
Thanks!
  • login the router and change it or reset the router and setup all over again
  • Have you found out the solution to this problem? If so please share.
    • FURRYe38's avatar
      Guru
