sdhammond2's avatar
sdhammond2
Follower
Oct 30, 2020
What cable modems work best with RBR50 router, and can I add additional Orbi extenders in house?
Two parts to my question.
1) I have a standard, bad cable modem from Spectrum I want to replace, but I have Orbi RBR50 already attached - what is the best cable modem I shoudl get?
2) I have one extender Orbi in my house off the main router.  Can I add another to another room?
Steve
sdhammond2@gmail.com
1 Reply
  • plemans's avatar
    1) I have a standard, bad cable modem from Spectrum I want to replace, but I have Orbi RBR50 already attached - what is the best cable modem I shoudl get?----Depends on your goals. I'd recommend a docsis 3.1 modem. I think the CM1000, CM1100, CM1200, CM2000 are all compatible with spectrum and capable of gigabit. If you don't need to hit gig speeds, then you can look at the lower models.
    2) I have one extender Orbi in my house off the main router.  Can I add another to another room?--yes you can. You can have up to 6 satellites.
    https://kb.netgear.com/000062035/How-many-satellites-can-you-add-to-an-Orbi-WiFi-System
    Steve
