pumpichank
Oct 29, 2016Luminary
What does "use other operation mode" mean?
On the Advanced Wireless Settings page, there a cryptic option under the WPS Settings. It says "use other operation mode". There is no documentation in the help section that I can see, and I've not...
- Nov 01, 2016
Cool, thanks!
VE6CGX
Oct 29, 2016Master
Do you try to use WPS? What are you trying to do any way?
pumpichank
Oct 31, 2016Luminary
I actually want to completely disable WPS, but the point of this question was different. There's an option in the admin screens that really isn't documented anywhere and it pretty obscurely labeled. I'm mostly curious -- what does this option *do*?
- Retired_MemberOct 31, 2016
Ap mode or repeater if available
- pumpichankNov 01, 2016Luminary
Cool, thanks!
