Ping32
Apr 24, 2022Aspirant
What is a TA number?
I have a Netgear product that has several different numbers printed on the bottom of the box: TA, S/N, MAC. I know MAC stands for Media Access Control, S/N stands for Serial Number. But what does "T...
- May 02, 2022
So I got info on TA, it's a internal total assembly part number that NG used to use. Not used or printed anymore. Nothing that users can use or be aware of.
Apr 24, 2022Guru - Experienced User
What NG product are you referring too?
Ping32
Apr 25, 2022Aspirant
Very good question! In this case it is the WNCE2001. But this is only one of many Netgear products that carry a "TA" number. So the question remains. What is a TA number?
- Ping32Apr 25, 2022Aspirant
For a more modern and sophisticated device example that uses a TA number, have a look at the Netgear Nighthawk R7000 and this 3 year old article (published 2019/03/20) on how to determine if it can be flashed or not.
https://blog.flashrouters.com/2019/03/20/can-i-flash-the-netgear-nighthwak-r7000-with-dd-wrt/
