Ping32
Apr 24, 2022Aspirant
What is a TA number?
I have a Netgear product that has several different numbers printed on the bottom of the box: TA, S/N, MAC. I know MAC stands for Media Access Control, S/N stands for Serial Number. But what does "T...
- May 02, 2022
So I got info on TA, it's a internal total assembly part number that NG used to use. Not used or printed anymore. Nothing that users can use or be aware of.
May 02, 2022Guru - Experienced User
Wonder if that could stand for Transmitter Address?
Ping32
May 02, 2022Aspirant
I have written a new reply. Where is it? It appears to have been queued for approval and it has then been approved but I don't see it in this topic. I will post it again.
What would something like that look like? What's the format? Would it be the same as for a MAC address? Something like A0:B1:C2:D3:E4:F5? This TA number looks something like 123-45678-90A1. That's 12 characters, just like a MAC address, but with very different separators (and in all the wrong places).
- FURRYe38May 02, 2022Guru - Experienced User
- Ping32May 03, 2022Aspirant
Thank you!
So it stands (stood) for "Total Assembly". As in number of units produced? Is it a combination of a part number and a counter (how many, and what was produced)? What was this used for?
I have this number for example: 100-14685-01R8
What does this mean? Does the "R8" mean revision 8 for example? Is this unit number 14685?
These numbers appear to contain some useful information, for the curious minds who like to tinker with their devices. This is the main reason I think that "TA" numbers were in common use on web forums discussions.
This seems like a way to uniquely identify a device. But isn't that the purpose of a serial number?... although serial numbers are usually non-descriptive and randomized.
