Uriah2040
Oct 08, 2021Follower
what is a WPA2 password for a 390 Netgear wireless router WNR 2000 v3,
Oct 09, 2021Guru - Experienced User
you can log into it and check/change it.
https://kb.netgear.com/23439/How-do-I-change-my-NETGEAR-router-s-WiFi-password-or-network-name-SSID
if you don't know it, simply connect with a hardwired device and login that route.
