billsea
Jan 20, 2016Tutor
What is my IP for IP cam?
I have just switched from WNR1000 to R6300 router. My IP cam worked fine with the old router, but I can not connect to the IP cam remotely with the new R6300 router. I can connect to the IP cam if ...
- Jan 21, 2016
OK it is working. I have a Comcast modem with a built in router. I had the router bridged to get the IP cam to work with the old router. I had to call Comcast to do that. Now that I have a new router I did not know that I had to call Comcast again to bridge to the new router. I called them and they performed the bridge to the new router and everything is good.
Thanks for all your help.
billsea
Jan 21, 2016Tutor
Thanks for the reply, but still no joy.
On advanced>set-up>internet set-up I changed several things. I tried - use default, then use computer mac address, then use this mac address with 1. old wnr100 mac, 2. new r6300 mac, then IP cam mac. Nothing allowed me to remotely access the IP cam. And, in every case the internet port IP address remained 10.0.0.2.
Any other ideas? I would appreciate the help.
Retired_Member
Jan 21, 2016did you reboot modem after changing MAC? make and model of your modem
