HJTeix
Apr 30, 2022Guide
What is the best R6080 Router Firmware
Apr 30, 2022Guru - Experienced User
Usually we recommend having the latest version unless you're having issues.
HJTeix
May 14, 2022Guide
Exactly, the problem is the bugs! Everyone I put had different bugs!
- michaelkenwardMay 14, 2022Guru - Experienced User
What "bugs" are these?
You are trying to run a racing car down a cycle lane. Your router's hardware can't handle it.
The R6080 has a top speed of 100 Mbps. But that is the connection speed to the network. Your 100 Mbps Internet needs a bit of slack to handle the tricky management stuff that has to go into delivering 100 Mbps from the Internet to your network.
There are no bugs in there. Just your choice of hardware.
What does that mean?
