zb
Nov 18, 2019Initiate
What is the new Netgear website address to login to C6300 AC1750 router, Netgear EX8000 AC3000 Range
Something changed! The http://routerlogin.net website is gone! I cannot log into my Netgear C6300 AC1750 router The http://mywifiext website for Windows is gone! I cannot log into my Netgear EX80...
- Nov 18, 2019
if you go to your computer (assuming its windows) and open a command prompt, then type ipconfig.
That'll give you your default gateway's address. type that into your browser bar.
or the default for the C6300 is 192.168.0.1 (unless you changed it)
Are you connected to the combo device? wireless? wired?
What changed if it worked before?
Is the combo device working?
Another thing is that this is the forum for general routers. Yours is a modem/combo device. This would be the forum for it:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
